Cannot connect Base Station
  • 1 Reply
  • 4181 Views
peterbest1954
Hello team.
I already have an Arlo Q which works fine. I bought a new Arlo Wire-Free system. I can sync my cameras to the new base station. The base station is visible on my network. I have green lights for Power, Internet ands Sync. When I log in to my Arlo app and when I log in to my Arlo account on the PC I go through the steps to add the base station. The app and the PC both recognise the new base station. It asks me to give it a name and select a time zone and then just logs me out.
What to do? Please?
UPDATE COMPLETED: Tue 2nd of May, Arlo team is performing an emergency update to the cloud
[ New ]
Dear Arlo customer,
On Tue 2nd of May, Arlo team is performing an emergency update to the cloud from 9PM to 9:15PM Pacific Time. Arlo users may not be able to log into the Arlo apps or the web portal during this 15 min update. But rest assured the cameras will continue to function as expected during this update and your recordings will be updated to the cloud as expected.
After the update is complete, you will be able to login and access all your camera activity as usual. We apologize for this inconvenience, and appreciate your patience and understanding.
UPDATE - May 2nd at 9:20 PM PDT
The update to the Arlo cloud has been completed with minimal down time. Users that may have attempted to log into the Arlo app or web portal during that time may have seen an error of "Incorrect Username or password". You should no longer encounter this issue now that the update is complete.
If you are still experiencing unexpected behavior with logging into Arlo please let us know at Arlo Support.
Thank You,
Arlo Team
[ New ]
Dear Arlo customer,
Thank You,
Arlo Team
