Cannot access Arlo cameras via cell phone (iPhone)
  • 1633 Views
budmcq
Cannot access Arlo cameras via cell phone. Okay via internet only. SSL Error just started on two different iPhones when out of internet range. Have re-installed iPhone APP with no success.
JessicaP
Hey @budmcq,
Could you show a screenshot of the error you are receiving?
And could you clarify on "okay via internet only"? Do you mean you can connect via data connection or Wifi?
budmcq
There is already a screen shot on file from a previous issue. I can not take a screen shot until I leave the house. This problem only occurs on the Arlo mobile iPhone APP when I only have Cell service to use, If I am in range of Internet (Web) access my Arlo APP works.
The error message only says, "An SSL error occurred and a secure connection to the server could not be made". That's it, that is all there is'
Again the Arlo Mobile APP will not work with Cell service, I get the error message
The Arlo mobile APP works fine on Internet (Web) service, so does my computers
JessicaP
Hmm, who is your carrier service provider? And do you have any applications running in the background to block the connection going on for the Arlo app?
