Can this whole system work with Satellite Internet?
  • 4 Replies
  • 3931 Views
Bwood98
Very new to all of this.....Can this whole system work with Satellite Internet? Speed up to 25mb's. Any advice or recommendations before the Satellite Internet is put in? Thx-BB
steve_t
Master Master
Should be fine. Upload minimum should be 1.5Mbps. 25mbps is around 3Mbps
All you need for the system to work is an ethernet connection to the base station that has internet access with ports 80, 123, 443 open.
If you haven't already bought an Arlo system, I recommend you get the Arlo Pro or Pro 2 and not the Arlo HD system
Bwood98
Thanks. Very helpful. Costco has them for sale but I didn't see which one they have.
Bwood98
Just looked, they have the Pro.
mhnatt
Luminary
Luminary
We run 10 Arlo Pro 2s at the highest quality with no problem using HugesNet Gen 5 as our provider (25Mbps down and about 2 or 3 Mbps up). As mentioned, unlike most talk about speed, upload speed, not download, is all that matters when discussing security camera limits. We did try CVR but that eats into our data plan too much and is taxing in the other cameras.
