Can't name base unit on mobile app
Is the mobile app down...I cant seem to name my base unit
Hi @Dhedges510,
What device are you using? Make sure you are running the latest version for the app.
Using a Samsung S9 ,downloaded the latest app.
Is the base a VMB3500? There's recent reports of the same issue. Swap at the store and/r open a case with support here:
