Is the running man for the camera in the Devices tab black or gray? Gray is disarmed. If black, try power cycling the base and open and close the battery cover to reset the camera.
If the running man symbol is black, check that the rule for that camera in your recording mode says to record when motion is detected and also that you get a push notification. Then turn the motion sensitivity up to 100 and don't forget to go back a screen and click SAVE. If you get a whole heap of false detections, work your way down through the sensitivity range until you get to a level which responds well but doesn't give too many false alerts
Glad you got your problem solved. With these cameras using a PIR sensor to detect motion, they won't work through glass. The Arlo Q cameras do though
