Can't Get Online After Moving the Router
I had the system working then i had to move my router after hooking everything back up I can't get back on. It seems I can't get the phone to air with the base. Help
Switching routers doesn't need you to do anything with Arlo. Disconnect the cable from the old one, plug it into the new one. If all 3 LEDs are green, you're good to go.
