Can I use the Tenergy Rechargeable batteries in my Arlo VMS 3330 cameras?
https://www.amazon.ca/gp/product/B01N0DVFA7/ref=od_aui_detailpages00?ie=UTF8&psc=1
these are the ones you want. dont necessarily need to order from amazon, but i found best price there for canada
if you get the gold colored 3.7v ones, yes. I'm using them.
if you get the silver 3.0 ones, like I first in error ordered, no. they'll work but give you less than 24 hr/charge
Yes, and I recommend you do as the single use ones are expensive!
