Can I use one as a Primary Base Station which connects to the internet and other as bridge?
I have two (2) base stations (VMB3010r2). Can I use one as a Primary Base Station which connects to the internet, and the other unit as a secondary “bridge” or node to Send the signal to the primary base station to improve my WiFi signal from cameras Distant from the primary base station? I have a mesh system (eero) and can also directly connect via Ethernet to my system the secondary base station. It seems each base station is competing with the other....
You can't use a base as an extender. You can havce 2 bases on one account with cameras connected to the closest one for best signal. There should be no "competition" when using 2 bases at all.
