Re: Can I have two different ARLO systems (accounts/apps) at the same time in my iPhone?
- Email to a Friend
My father in wants me to also keep track/control their ARLO system when they travel?
Since they have their own setup/account I'd like to have an parallel app on the iPhone at the same time for them.
Is this possible? How do I set it up?
- Email to a Friend
You can't run two apps - the easiest thing is to have them grant access to you so that you can see all the cameras in your app. If I remember correctly you can rename their cameras in your app that won't intefere with the names on their app. For example in your app you could put the first character in their cameras names to something like P-xxxxxxxxxx.
Upon their return, if they don't want you to see their cameras, they would just de-select the cameras in the Grant Access section.
Brian
- Email to a Friend
Hi Brian
Thanks for a quick reply with suggestion how to solve.
I'll test this and hope it works.
Br Thomas
