  • 2 Replies
  • 14552 Views
glennw431
can this arlo be installed on two cell phones and use from either one
Yes. However, if you're just using the master account, when a second person logs on to check, the first person will be logged out. This is by design. If you need simultaneous access, use Settings, Grant Access to the other person's email address and follow the emailed directions carefully. That way you won't get logged out.
Yes... the first install will be the primary account holder... then the primary holder uses GRANT ACCESS ( in settings ) to share the cameras to the second account ( toggle on each cam and give admin privileges )
