Can Cameras be turned off?
Hi
(yes a bit of a strange ask for security cams)
I'd like to be able to switch off a camera during scheduled times. Like completely switch it off. So you cannot even log into it online and check the feed.
The cameras are shared with other family members, and I know as the account owner I can disable access to cams. But I'd like to do this automatically and at scheduled times.
Is this possible?
Cheers 🙂
No.... unless you pull out the batteries
billgreenwood wrote:
Looks like one may sometimes have to turn into a coat hanger 🙂
I put one cam on a small camera tripod, about $5... When home it faces the wall, when we go out, we got into the habit of turning it into the room.
Solves any possible problem of someone looking at that cam.... easiest solution i had at the time..... or you could use a sock ! 🙂
TomMac wrote:or you could use a sock ! 🙂
Just don't suggest a handkerchief...
