Cameras wont coonect
  • 1 Reply
  • 54 Views
OzzyDee12
I have 3 VMB4000 hubs. I have 7 cameras. These all worked with the old App and I had each hub with 2,2 and 3 cameras. No Problem. Ssystem was never used for about 1 year, When I tried to nre-install them all, I was forced to use new APp and now can only get 1 hub with 1 camera to connect. No matter how I try to Add/Connect the others , n o joy. I have 3 different user ids. Driving me nuts. Must be soemthing simple. I have deleted 2 accounts to leave the working one, re-added the accounts, factory reset the hubs etc and still can't connect anything. Help please
BrookeN
What do you see on the basestation when you are trying to add them? Is there any error messages? Have you done a reset to the baseseations?
