Cameras went offline now basestation
When I hold the pinhole reset for roughly 10 seconds the power light shows Amber. No other lights turn on. When I release then the 5 flashing green lights flash over and over. I removed the device from my app and when I try and add new device it never recognizes my basestation and continually fails. What could be making it just flash 5 green lights but never seem to connect to the internet.? My router works.
Here is the article on how to perform the factory reset. I believe you have done everything correctly, but the article says that the base unit will be removed from your account and must be setup again like setting up a new system.
https://kb.arlo.com/1057976/How-can-I-reset-my-Arlo-base-station-to-the-default-values
Here is the Quick setup guide for your system.
https://www.arlo.com/en-us/images/Documents/Arlo_Wirefree/arlo_wirefree_system_installguide.pdf
Brian
Having all the base LEDs flashing all the time indicates a hardware problem. Open a case with support here to use your 1 year warranty.
Last time I looked the Arlo base station only had 3 lights. What 5 lights are you talking about? Your Router?
Brian
The original base has 5 LEDs although only 3 are useful.
