  • 2 Replies
  • 2807 Views
NeilPerrett
I have just set up our new system.  Base unit and 1 camera have worked with no problem.  I have tried all troublshooting.
My other 3 cameras, turned blue when batteries were installed.  Pushed the sync button and it would start off correctly with the blue light flashing the way it is suppoused to but then it would turn to orange flashing quickly and then stop and not sync.
It is not the batteries they are charged.  We have reset we have turned on and off and we have opened the battery unit on each and let sit for 1 min then attempted again only to have the same thing happen again.  We have repeated this about half a dozen times.
Still with only 1 camera working.  Please help.
Regards
The usual issue is pressing the base station sync button too long.  Press for <1 second, wait for the base LED to start blinking and then press the sync button on the camera.
You say the batteries are charged... what type and voltage?
The Amber flash means a failed sync for whatever reason.
