Cameras not recording in motion detection mode
  • 5 Replies
  • 4211 Views
Mford
Cameras not reocrding in motion dectection mode.  Manual recording and shap shots work and send videos, images to library.  I have the scheduled times correct.  LED lights do not flash when motioin dectedted.  The Hardware  version VMS3330, Firmware 1.2.2688. Base Sation Model VMB3000, SR No. 48936376A14A4
5 REPLIES 5
Armed the cameras, go to the LIVE view screen and check the "running man"... He has to be black for motion detect record, if Gray you mode must be checked
Mford
The "running man" is bacak on all three cameras before I initiate the LIVE option. After LIVE optipon is activeated the figure is grey.
That is Normal... when you go LIVE, you over ruling the previously set Mode
Have you check your sense levels ? ( In the mode , accessed by editing )
Also , there are No leds that flash on the camera EXCEPT in test mode... to arm you go to MODE >ARMED
Mford
Motion senses is set to 100% in Settings for wach camera.
Ok... went back and read...
Firmware 1.2.2688
I believe your sw is out of date , maybe causing issue...
Cam should be 1.2.10342
base is 1.8.1.1-10234
So pull batteries and replace in cameras, power button recycle base... look in cameras settings as see if there is a triangle ( Ithink thats what they use ) for a possible update to sw...if so click on it and wait over night ( updates done usu early morning at night )
