Camera won't connect after installing new batteries -
  • 5 Replies
  • 3614 Views
mhj9090
firmware 1.2.4941 Hardware H7
mhj9090
Thank you--- I attempted this 3 times, and it finally now shows a firmware update, so all s/b good!  Thank you again!!
5 REPLIES 5
F150Fan
What have you tried? Did you try to resync the camera?
mhj9090
I did -- even switched out the batteries thinking maybe the new ones were bad, and still no luck.  I can see the camera on my phone but it still shows its time to replace your batteries
I believe that's an older version of SW...  should be Arlo Wire-Free Camera v1.2.10342
So Pull batteries, make sure they are in correctly
Go to settings and Use REMOVE DEVICE, then bring it back as new ( resync )
Power button reboot the base,.... let it come back online
Check for any red triangles near the camera which would indicate an update is available....click on if so and wait over night for update
mhj9090
Still not connecting - I removed it and now the base station doesn't find it at all
mhj9090
