Camera will sync properly with base but doesn’t connect
Camera will sync properly with base but doesn’t connect. Base camera led light blinks green then turns solid amber? We lost power during Irma and hasn’t worked since power came back on.
I would reset the whole system to avoid wasting time. Remove everything from Settings, My Devices. Use the Add Device button to add the base and sync the cameras.
Edit: Reread your post and see that you get a solid amber Camera LED. That means the base needs to be claimed. Try adding it back in using the Add Device button before resetting.
