Camera will not sync.
Camera 1 had no troube connecting but I cannot connect cameras 2-4 to the base station. Amber light flashes rapidly indicaing to try again but I keep trying. I have turned the base on and off, disconnected the base and reconnected it, also have taken out batteries of cameras, and even follwed directions even to connect. Is it because I need stronger wifi? I have a older verison router with one network in a big house.. PLEASE HELP!
Are you bringing the cameras within a few feet of the base station? Try moving the base station a bit further away from your wifi router or restarting your wifi router. It may be interference
You might give this a shot, for what its worth.
1) Turn the power off on your wireless (WiFi) access point. (not the Arlo base station, just your wireless access point which some people call a router). Note you will lose connectivity to the Internet for a few minutes.
2) Go through the steps of syncing a camera to the base station. See if you get the amber light again, or if it seems to sync correctly.
3) Power back on your wireless access point. Wait a few minutes for Internet connectivity to work again. Then login to to the My Arlo web site and see if the camera shows up.
