Camera will not stay online.
I have one camera, updated firmware that will not stay online any more. I can disconnect and reconnect and still only get it to stay online for 2 minutes then it drops off line again. This is with it mounted, 20 feet line of sight, or sitting next to the base station.
What is the solution?
5 REPLIES 5
Reset the camera by removing the batteries for a few minutes
Also, swap cameras around to see if it's the camera or the location.
So I guess I should have said it in my original post that I've changed the batteries and it still does not stay connected.
I guess you missed the part where I said I tried it in its normal location and moved it all the way up to where it is sitting within 2 foot of the base station and it still doesn't stay connected.
Open a case with support using the Contact Support link at the bottom here.
