Camera video switched to red.... How do I correct and return to normal video?
  • 2 Replies
  • 2231 Views
BossTweeter
One of My three cameras has switched to showing red pinkish video....?  How do I correct this fault and return to normal vide
The IR filter is stuck. Open and close the battery door. If still stuck, contact support for replacement:
happydays-ni
There's an easy fix for this one. Turn the camera physically upside down. Then go into the software app and tell it to show 180deg picture. It won't trouble you again.
