Am I missing something? Is it possible I messed up some setting somewhere?
Open a case with support. That's the only way to get hardware support.
My question is for those getting replacement cameras from Arlo, do your replacement (I read as often refurbished rather than new!) cameras work right side up? Trying to decide if I should return to Best Buy now for a full refund and go with something else or not. Not feeling very confident in this product!
I dont think its that widespread a problem. I've had a 4 cam set in Jan. on one and one cam only it started to happen this summer and then only once every 4-6 weeks. And since opening/reclosing battery door cleards, I can live with problem. Yes there are other weatherproof battery operated cams on the market, and if you read up on them you'll find they too have problems. I have one battery operated cam from a competitor, and while it has some features I wish the Arlo had, there are many things the Arlo has that it lacks.
I opened a case had one response and have been waiting a week and still no response they told me to call them but I havn't heard from them there service is makeing me wonder what I have bought into.
And you simply don't need to live with it. You have the return privilege at the store as well as the 1 year warranty that you can utilize by opening a case with support here. I don't understand why so many people have trouble understanding that these options are available and to use them.
when Netgearcon cluded I had a defective Base station I gave them my cc number thy sent me a replacement incl return shipping label pointing out I had 10 days to return the defective station or they zing mycc card for the cost. I think thats a fair system.
should be straight forward. 1ye ar warranty unless refurbished
"And you simply don't need to live with it. You have the return privilege..."
Yes you do. I have been through three sets of three of them from the local Wal-Mart over the past three weeks. Goes for a few days to a week, and one camera randomly decides to go pink during the day. It's annoying, but I guess in the end, if I have to keep replacing them this way, I'll never have dead batteries.
"Flip the camera upside down and then flip the image in the app..." Interesting. I'll have to try that.
I'd be concerned that if exposed to weather, rain might get in it as the battery compartment isn't sealed. If it drowns, head over to where you bought them, buy a new set, and take the broken bodies back for a refund.
I've only had these for coming up on a month, but from what the long-timer / "Netgear / Arlo can do nothing wrong defenders" say, that's the repair method. Play the RMA game, or return them repeatedly. On the bright side, you get a new set of batteries on every trip doing that. I ended up buying mine at Wal-Mart - first set was from Sam's - and as long as you have your receipt and bring everything back, it's a simply process, and at the end, you feel like you accomplished something unlike dealing with Arlo customer service. Oh wait, you did!
yes... Open battery door and reclose to reset camera and test during day.
If still reddish or happens again, contact Netgear Support https://www.arlo.com/en-us/support/contact.aspx
I had a camera go bad they sent me one but it wasn't my arlo pro they sent me the cheaper model what can I do. customer service said they sent me the right one. They didn't I have the box to prove it.
Use your case to correct it.
I can't they closed it out.
Is this the camera that went bad with the pink tint?
