Camera settings reset after battery dies
First, don't let the battery die - change proactively.
Next, the setting isn't in your camera - it's a function of settings in your account that loads into the base. I haven't heard of this before but I would reboot the base for starters and then use only a web browser to check/set anything in the Mode tab since the apps can do weird things sometimes.
yes I have cycle down the base station and repositioned it.
It has ran for the past year and a half perfectly… Only with in the last few months I’ve been experiencing this problem.
I'm going to suggest resetting the system and start fresh. Something is goobered in the setup. It may be bad equipment but first remove all devices from Settings, My Devices. Hold the reset button until the LEDs flash amber. Open and close all camera battery doors. Use the Add Device selection to claim the base. Sync the cameras. Update firmware as you go if prompted.
Be sure to note all settings, modes, rules and schedule before you start to speed rebuilding.
