Camera screen is red
Hello, ive problems with my arlo camera. the picture is totally red.
the serial number from the camera is: 48B45979D2D46
here is a screen:
https://i.vgy.me/PwfB8U.png
best regards
This has happened before... check the FAQs. The IR filter is stuck.
Usu, pull the batteries and replace to reset , test.
If it occurs again, and less than a yr old , contact Arlo support for warranty.
There are other possible fixes in the FAQs.
