Camera recording without command
When I check the web portal and look at my three cameras, one starts recording. The other two do not do that. This one just started to do it and operated perfectly for several days after being set up.
Boat52,
Do you notice this happening only when accessing the cameras via the web portal or do you also notice this happening from other devices (mobile app). Does this occur when accessing the cameras from a different network than the one the base station is connected to?
Only happened once and now it is not a problem. Odd, but will move past the hiccup. Thx.
