Camera not connecting to iPhone
Camera had battery change wouldn’t then connect to iPhone on the app.. tried base reset, changed batteries...re sync etc etc just comes up as can’t find .. loosing the will now !!.
works fine on husbands app
Since it just your phone app, try uninstalling the app reinstalling it, or even rebooting the phone. Since it works on your husbands it is not the system.
It sounds like your account has been granted access. That means you don't try to use Add New Device - you just log in. If that isn't working, have your husband remove your account in Settings, Grant Access and add it again.
Hi .. already tried that too ... even set up a new email account and he’s allowed that one ... still won’t add the camera ..
@Jools282 wrote:Hi .. already tried that too ... even set up a new email account and he’s allowed that one ... still won’t add the camera ..
As jguerdat stated he can not add a camera, You must select the cameras for him to see in your Grant access settings if you have not done that.
he’s deleted me and added again under different emails .. still not adding
@Jools282 wrote:
Hi ... my husband is the main account holder not me ... he’s got all 3 cameras ... I’ve only got 2 ..
Ok I mixed it up, has he selected the third cam to view for you in his grant access settings for you to see just in case to clarify.
Please contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link. Arlo Tech Support
