Camera is only 10ft away from base station and drops offline after 48 hours
  • 1 Reply
  • 1116 Views
Thanksalot
Camera is only 10ft away from base station. Arlo, is this a fault with the camera? My other two are completely fine. Have tried swapping out etc with same result - reconnects then after 48 hrs goes off line
manfredz
Hero
Hero
It would sound like it.  I would contact technical support using one of the methods found by following the Contact Support button at the bottom of each page.
