I've had this Arlo system with 4 wireless cameras for about 18 months. 3 of the cameras work fine, one is unreliable and frequently goes offline with battery draining very quickl despite no video being taken. The frequency of failure has increased over time. Now, I get 1 day of usage, it goes offline, I reset and then 8% battery usage. This would seem to be a hardware issue that has been present with this particular camera since day 1; it has now exacerbated so it is now unusable.
The camera is not far from the base station (in fact, nearer than the others) and has no events on it - my library is empty so it is not actually doing anything, excepting eating batteries and failing.
How can I get this camera fixed or replaced? Is there a solution warranty/guarantee for cameras after 12 months or should we just expect a working life of 12 months?
Rapidly draining batteries is often a sign that the base is trying to constantly communicate with the camera and failing. It keeps repeating the communication attempts until the batteries finally drain down.
I am assuming that you are having to change the batteries quite often which means that every time you change the batteries you must resync the camera to the base.
It has been noted elsewhere that sometimes one of the batteries will not seat properly forcing the camera to work with two batteries instead of four which cuts the useful life to be cut in half. Try to change the batteries and drop them in letting gravity seat them. Then close the lid letting the lid exert the force to properly seat the batteries.
Secondly, try swapping the camera with one where the batteries are lasting longer and see if the problems follows or not.
I don't think the warranty lasts longer than 12 months.
Brian
Agree that the batteries are probably draining because the camera has lost communication with the base
1. Swap locations with another camera that works well
2. Move the base station a few feet further away from your wifi router as there may be interference
I am having the exact same issue. The problem is not signal strength as it's the 2nd and 3rd closest cameras to the base station, out of 5. The signal strength is medium, and better than other cameras that aren't having this issue. I have gone through atleast 6 sets (48 = $68) of batteries (expensive!) so it's not the batteries as they've clearly been switched out plenty.... It's not the location as I've moved these cameras around to different posts and the same two always have this issue. They suddenly go offline, and if I don't catch it immediately (within 24 hours), they drain the batteries down from 90% to zero within a day or two.
Liz8811,
Please contact the Arlo Support Team to further investigate this issue. You will find several options for contacting support in the provided link. If you have any additional questions/concerns feel free to private message me. I would be happy to help.
Im having the exact same issue and found this thread. Im not sure of the suggestions discussed is going to solve my problem. Have 3 cameras and 2 of them seem to do the same sort of thing. They go offline and batteries dead. Replace the batteries (have done this twice now) and in a few days they are offline and batteries dead again.
Hi there.
Was there a solution to this problem. I have the exact same problem described. I've attempted all recommendation, but still the same issue exists.
kwongke,
If none of the troubleshooting above offered by brh and steve_t help resolve the issue, please contact the Arlo Support Team to further investigate. You will find several options for contacting support in the provided link. If you have any additional questions/concerns feel free to private message me. I would be happy to help.
