Camera did not sync and now will not turn on
Camera did not sync and now will not turn on. I replaced batteries with new ones. Camera still does not turn on.
8 REPLIES 8
Be sure the batteries are good. Using a voltmeter, good batteries are ~3.2v, dead are ~2.75v. Make sure the batteries are installed with the proper polarity. Don't push the batteries down - let the door do the pushing. When the door closes, you should see the LED flash blue. Anyluck?
No change. The camera does not turn on.
When I initially tried to sync the camera, it appeared to work properly but did not sync. I followed the instructions, turned the camera off, and attempted another sync but the camera never came back on. Changed batteries 3 times. No change.
This is my 3rd camera. Did not have any problems with the first 2.
Especially if you get no LED indications at all, opening a case with support or swapping at the store seems like your next move.
Ok, since this is a reconditioned camera, how do I open a case with support, I doubt the store will exchange it.
Use the Contact Support link at the bottom here.
