Camera connection
  • 1 Reply
  • 1952 Views
DarrenM02
Where my camera is located. It has a connection but very minimal. Takes a while to load when I try to look at live video. So I bought a WiFi booster. How do I connect that camera to the WiFi booster? It’s the same network just boosted with a electrical plug in type booster.
You can NOT use a wifi extender for the cameras... ( they talk only to the base unit )
BUT, what you can do is use the extender ( if it has an ethernet port ) to centrally locate the base for a better connection to the camera
OR
Use an extender to add a second base unit and sync the closest cameras to each base ( the only real way to expand coverage of arlo is with multi bases )
