Camera VMC 3030 one camera burning through batteries
I own two of these cameras and one has started to burn through batteries while the other is still at some 95%. Any suggestions, nothing has changed or moved. I'm seriously considering going to wired camera, these batteries are just too expensive.
Is the cam burning through batteries making lots of recordings?
Try swapping locations between the two cams to see if problem shifts to the other cam. If so its the location; if not its most likely a setting or bad cam.
