CVR
When will CVR be fixed? It has been down for months on a camera that I pay for. Support has not been helpful.
Reading over the case I see that your CVR timeline is missing. Can you please try resetting the camera and adding it back onto the account? Here is the steps to perform that:
https://kb.arlo.com/000062880/How-do-I-factory-reset-and-re-sync-my-Arlo-camera-Arlo-Secure-4-0
@GrandmamaDeb are you still seeing this same behavior after the steps preformed that I provided?
Yes, same issues. I’ve gone though many steps of troubleshooting with the team. Nothing has worked, on my case they are saying the technical team is aware of the issue.
Case number: 44860621
