CAMERAS GO OFFLINE DAILY. HAVE TO PRESS BLUE BUTTON TO GET THEM TO WORK.
So annoying. Any random 4 of my 5 cameras will go offline and a reboot of base station doesn’t fix the issue.
I have to hang out of windows to reach cameras that are off and hit the sync button to get blue light flashing then they reconnect.
Such a pain in the. Seriously thinking of witching you RING as my RING doorbell has been trouble free since I installed it.
Peed off.
Hi @Andyr46
When did this issue first occur? Have you moved the base station to a new location?
May I ask which troubleshooting steps you have performed so far? I don't want to suggest any prior methods you have previously performed.
