Blurred or green screen on one camera
One of my cameras sometimes gives me blurred images or part of the image is green. What is wrong?
It could be faulty equipment which would require a trouble ticket for possible RMA. It could also be an issue with your upload speeds via your ISP. Have you tested this to verify that you have >1Mb/sec uploads?
Could also be intereference from another device.
I also seem to have this issue. One camera, during some recording sessions, will have sections of the video where there is nothing but green screen, or the action will freeze. My upload speed is fine and my other camera, which has to shoot through two walls and is twice as far from the base station as the one having issues, records video just fine. The camera which has these issues is only about 10 feet away from the base and has a direct line-of-sight to the station. This is the camera that suddenly went from 90% battery to a 25% level over night. Since then, it has stayed at 25%. This is all very troubling since I travel so much.
Temporarily swap the cameras around to see if the problem follows the camera or stays with the position.
And have you tired the suggestion in this thread?
I have tried resetting and different batteries and still shoots blurry or green screen 85% of the time. I travel alot and makes me nervous that something made it go off but all I see is blurry or green
If you have more than one camera, swap them around and see what happens. Is the WiFi signal strength good? Can you live view with no issues? What's your upload speed through your ISP? You may need to open a trouble ticket for more help and a possible RMA for a defective camera.
I have switched the camera and it does the same thing no matter where I put it. The signal strength is good not sure of the streaming speed. Sometimes when I do live feed it will be green or just disconnect itself
Jetgirl,
Please contact the Arlo Support Team to further investigate this issue. You will find several options for contacting support in the provided link. If you have any additional questions/concerns feel free to private message me. I would be happy to help.
Has anyone figured anything out with the blurred or green screen??
I assume you're talking about pixelation? If so, there is a MONSTER thread on this issue that can't seem to get Netgear to own up to it. We thought the recent firmware release fixed it, but it happened at the same time of the AWS outage, and the issue can back a few days later, which leads me to believe it is their servers/datacenters causing this issue. When AWS had their outage, things magically got better, i'm thinking it load balanced us to a closer/better server/datacenter.
