I've been blocked by cloudflare in my initial attempt. I tried to login with node.js code to:
https://ocapi-app.arlo.com/api/auth
in a post request with a json payload with:
{"email":<my_registered_email>, "password":<registered_pwd>}
I read this is the first step to get a session id. What did I miss?
I can wait 24h but.. if I do the same, I expect the same outcome.
What are you trying to do?
Can you log into my.arlo.com?
Yes I can, and I do.
What I am trying is to integrate API access to my self-made home automation system.
The intention is to take live snapshots from my camera (available at my.arlo.com) and also -if possible- fetch the feeds in the tool.
up
please....
I do not think this is possible. If you have a subscription you can reach out to support and discuss it further.
