Battery life
Just opened the Arlo system and installed - battery life has reduced by 10% in 60-minutes - hope this is not going to be an expensive purchase/mistake!
Just got mine today as well. 2 out of 6 cameras been armed for about 6 hours. Still @ 100.
How many clips do you have all together? And what's the video setting at
Just set them up, only about 4 clips from 2 cameras and no clue how to find out what video setting I have - sorry!!
In normal usage my Pro battery has been getting 3 months.
Just so you know, the live viewing and recording use the most power, having armed to detect motion then record uses a lot less.... Spec usage for time on battery is 5 or less recoding per day....YMMV based on yor own use
