Battery drained
Hi I only have my Arlo turned on during the night and when I switched the cameras off this morning my battery life was on 74% but when I switched it on tonight one of the cameras says I need to replaced the batteries. There is no way it could of been drained, it had 74% when switched off this morning and hasn't been on since? Has anyone else had this happen? How did you fix it. I am not really keen on buying new batteries if this will happen again.
You should reset the camera...which is done by removing batteries. Then you should move the camera to see if the issue is the camera or location. ( problem follows camera )
Obv, if it continues, contact Netgear Support
