Battery Level still shows 0 after replacement.
  • 4 Replies
  • 4571 Views
  • 5 In Conversation
DebraJo
App said, batteries low. I replaced. Camera is hooked up to base. I have open and closed battery doors. I have refreshed. I have turn on and off base. Camera does not show live and the battery level still reads zero. please help before I throw it away... (aggravated)
That's assuming the the camera is a Pro. It would seem that this is the original camera.
Why throw it away when all you need to do is open a case with support in case it's just bad hardware?
jcwrks
Luminary
Luminary
Does cam show live if you connect the cam to the wall charger?
Sharonshine65
I am experiencing the same thing. How was your issue resolved?
manfredz
Hero
Hero
If we're talking about Arlo and not Arli Pro here are some possibilities:
1 Replacement batteries are duds.  Easily checked if you have another cam
2. Replacement batteries not in right or not making a good contact, such as bottom springs stuck down.
3. If Panasonic batteries, the plastic covering hasn't been removed and is covering the contacts.
