  • 6 Replies
  • 4268 Views
aja
I installed my cameras outdoors about a month ago. Because one is always on, it gets a lot of use when cars go by. After a 2-3 weeks, I noticed the battery levels start going down, first to the half-way mark, and then to the 25-33% mark (which I assumed was because off heavy use). However, during the last week, all of the battery levels went back up to 100%, without me changing any of the batteries. Has this happened to anyone else?
(The weather had been in the 40s at night and 60s during the day, but I read that only extremely cold weather affects the battery levels).
6 REPLIES 6
I was just reading another post about similar behavior.  Not sure what would cause this other than some server-side thing happening.
aja,
Consider opening and closing the battery compartment door to reboot the camera. After the reboot, are the batteries showing the expected percentage?
Barlborough
Checked one of my cameras yesterday 70%
This afternoon 4%...........
Batteries previously replaced end December last year......
Try resetting the camera and display by opening and closing the battery door. Does the percentage change? Maybe a power cycle on the base, too.
aja
Update. A few days after posting, I received an email that the battery level was 8%, and needed to be replaced, even though the level on the "live" mode showed 100% just the day prior. After the email, the "live" mode battery level did go down.
Maybe there's an issue with the "live" mode reading the battery level correctly until it's about to completely run out.
If you're viewing in a browser, perhaps clearing the cache would help.  There have been instances where the browser is using old data that a cache clear helps.
