I have one camera out of eight that the batteries only last 2 or 3 days. It gets very little use, maybe every other day it might pick up motion and record. I use Duracell batteries and I check them before I install them. I called tech support and they are blaming the batteries I'm using. They are sending me some batteries. I think it is a camera problem. The first set lasted about a week. I thought it might have been too far from the base station so I reloacted it to about 20' from the base station. The next set lasted a couple of days. The third set (used but still read over 3 volts) only lasted about 12 hours.
I shoud have updated this weeks ago. I installed the batteries that Netgear sent me and they lasted about a day and a half. Support then agreed it was the camera and sent me a new one.
Thanks for the responses.
Swap the bad camera with a good one. If the problem stays with the camera, it's obviously the camera.
Then contact support using the Support link above. If it's bad hardware, that's the only way to get it replaced.
j-f,
Camera firmware 1.2.7730 released recently with fixes addressing battery optimization. Has your camera updated to this firmware?
You can see the release notes for this firmware here: Release Notes – Base Station FW 1.7.8_7427 and Camera FW 1.2.7730 14th September 2016
The only way to "try" and force a sw upgrade is to reboot the base via the power button and wait over night.... the other option is a bit messy with a full reset.
My base and camera hadn't updated for a couple of days so I restarted the base using Settings, My Devices, base, Restart button. That caused the update to occur for both the base and camera.
