Base station power supply
  • 1 Reply
  • 2786 Views
mnmmom
Anyone know where I can buy another power supply for the Arlo base station? If so, what voltage is recommended?
I ended up with a "defective" base station in which Arlo replaced for me... however in my chaos I neglected to note that I was to return the base station ONLY, and not include the power supply. I now have a new base station, but no power!
I don't ahve easy access to my power supply but look on yours for the information needed.  The input and output voltages and current should be the same (you could use a higher-rated output current if need be) as well as the polarity of the power connector to the base.  As long as those match, you should be fine.  There are some "universal" types that would give you options but I'd try to find one that closely matches in the first place.
