  • 41 Replies
  • 6229 Views
  • 4 Likes
  • 6 In Conversation
Blueocean12345
Base station is not storing local recordings all of a sudden, I tried everything, resetting the base station, resetting the usb drive but nothing.
i have read other posts that the base station might need a software update.
Hardware is VMB4540.
is this another way of telling the customers to use the subscription plan instead, this is very frustrating.
41 REPLIES 41
@Pythony wrote:
like this:
There should be either four or five controls - not three
The english text for 4 controls is (left to right)
  • Devices, Library, Mode, Settings
Five controls is
  • Dashboard, Feed, Emergency, Devices, Routines
Your icons look like "Library" (4 controls), but for some reason you aren't seeing "Settings" in the far right.
ShayneS
The Arlo development team is currently investigating reports of this behavior. We will provide an update as soon as we have more information to share with the community.
Pythony
Hi ShayneS,
Thank you very much for your attention. If your team needs more information or data logs from my device, please let me know how to copy it to you.
ShayneS
This should now be resolved, please let me know if you still experience this.
Baz2399
I still can’t access my recording locally
alex_loo
Virtuoso
Virtuoso
hi @ShayneS , still not working.  more details report in this message.
Alex
Can you provide more details?
  • Are you getting an error? Or just not seeing recordings
  • Do you see "Feed" and "Dashboard" in your app menu?  Or do you instead see "Library"
  • Have you ejected the storage using the app, and then connected it to a PC?  When you do that, are you seeing recordings?
ShayneS
Thank you for letting me know. I provided this information to the dev team, and I will add more info as soon as I hear more.
Baz2399
I see feed and dashboard and yes I can view the videos on my computer with the usb. No videos on my iPhone though . Local shows no events no videos
Did you also try
  1. going to the devices page
  2. selecting the smarthub tile
  3. selecting "storage settings"
If you don't see the recordings there either, then you might try uninstalling and reinstalling the app.
Baz2399
No recordings to see. I uninstalled the app and re installed it and there’s still nothing
Ok.  Did you try toggling "View Recordings" on and off?
Baz2399
Yes
@Baz2399 wrote:
Yes
Although it is a PITA, you could also try removing the cameras and smarthub from the account, do a paper-clip reset on the smarthub, and then add everything back.
Baz2399
It’s working now. Didn’t have to remove the cameras and reset everything
ShayneS
@alex_loo
Thanks for the info, can you create a new thread with this information and tag me in it.
alex_loo
Virtuoso
Virtuoso
@ShayneS wrote:
@alex_loo
done.  I have created this new thread.
Alex
