Base not reconized by android phone or web site.
  • 5 Replies
  • 19015 Views
mike_vest_1961
I have a new install and I cannot get my base registered. I have a green power light and a green internet light. But cannot get my phone or browser to work with it.
5 REPLIES 5
RX
Have you followed the steps described on page 4 from this link: http://www.downloads.netgear.com/files/arlo/Arlo_UM_23Dec2014.pdf ?
There is also a video about Arlo installation in youtube, you may want to watch it as well.
Since its an initial setup, you may want to perform a factory reset on the base station.  Check this link as reference then go to #8: https://community.netgear.com/t5/tkb/articleprintpage/tkb-id/arlo-knowledge-base/article-id/61
mike_vest_1961
Thanks, but I have already did a reset on the base, and the documentation states to put in serial number manually if the system doesnt reconize it. But it doesnt allow for manual entry.
So far...still not working. Will likely return the system.
chicagoslim
I'm having the same problem, did you resolve or just return? For an easy setup this is crap
mike_vest_1961
Returned it. Found a Vuezone system instead. Much easier.
Mike... fyi, Vuezone is really the first gen of Arlo ( private company picked up by netgear a while back ). I'm afraid tho it may be easier, you will find the quality of the videos a lot less than Arlo ( had a vuezone system before Arlo myself )
Good luck
