Anyone have a solution as to why the Arlo Base station is not sycing with the computer or the APP on my phone? I have tried a factory reset, unplugged the device, tired several ethernet cables, made sure it was plugged directly into my router and the power is plugged in. Both the power light and the Internet light to say I have power and the internet is connected and green. This has been the most frustrating set up ever. I might just return this product as it is not as easy as it seems.
Thanks for the help!
What happens when you try and set up an account and sync the cameras?
This is very unusual and not indicative of normal setup. Just to be clear, both the power and Internet LEDs are green, right?
As soon as the account is set up then start with the camera syncing process.
There is no syncing of the base that needs to be done. It just needs to be connected to your router and the computer being used to add the camera also needs to be connected to the same router by wifi or cable.
Here is the quick start guide
https://www.arlo.com/it/images/Documents/ArloPro/arlo_pro_system_installguide.pdf
I have moved this post to the correct section.
deidre4567,
Did the installation guide above help? Please let us know if you're still experiencing an issue.
deidre4567,
Please contact the Arlo Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
