Base goes offline
Arlo base station goes offline. Symptoms: VMB3000 drops out of router; 3 lights on base; the computer clipboard is clear, no other apps of programs running. Arlo is running on a Windows 10 system with 8Gb memory; router is Linksys WRT 1900AC. Basicall, it just goes away randomly.
Ford27t,
Does the LED behavior on the base station change at all when this occurs? What error messages are you seeing?
