Base Station
  • 26048 Views
tomtom213
System was working find for two days Now I get a message on computer the system has tured off and the green power light is
blinking.
David_NG
Hello tomtom213,
What light is blinking? The power light, internet light or camera light? And what color?
tomtom213
I stated in the orginal post that it was the green power light blinking??
Got a notice on the site that a update was ready, after the update the system seams o.k. The green power light stopped blinking and went solid green.
snip3rboy
In the manual, it is described thatthe blinking green Power LED indicates that an update is available.
The system auto updates early in the morning if an update is available. It does this only if the cameras are idle.
You can also update earlier through the app, just like you did.
