Base Station worth upgrading?
Currently running Arlo cameras on a VMB3010 base station but signal strength is getiing quite poor. Is it worth upgrading to a VMB4000 base station? Anyone with similar experience? Thanks
Would say yes....
You pick up the siren in the 4000 base and more important the USB backup port for a spped stick ( so if armed and the internet goes down it still records to the backup )
Save the old base as backup or for a second base ( like backyard ) which can have a separate schedule or mode
Thank you - will get rolling on that!
I can upgrade my base station
