Automation triggering separate camera activation or mode change
  • 1 Reply
  • 722 Views
castro8
Hello, I feel sure this will be dummy obvious after I hear it. Currently using Arlo Gen 2
Current setup:
AWAY- (Living rm ON/ Dining rm ON/ Bedroom ON)
HOME- (Living rm OFF/ Dining rm OFF/ Bedroom OFF)
STBY- (Living rm OFF/ Dining rm OFF/ Bedroom ON)
While in STBY I want motion detection in my bedroom to either switch system to AWAY mode or trigger the other to cameras to start recording
You can't switch modes using motion detection.
What you could do is cross-trigger the cameras, so motion detection in the bedroom would start a timed recording on other cameras.  Probably not exactly what you mean, but that is as close as I think you can get to what you want.
