in mode I see an option for "armed" and one for "motion on." I'm not sure what the difference is. Thanks.
The two NEW defaults are ARMED ( all on ) and DISARMED ( all off )
Motion ON is a left over from the older SW which had a big update late Dec '15.
I would recommend that any older MODES be copied by making new ones with the same settings but a new name and then remove/deleted
Some of the older custom modes don't work 100% when they carried over.
Very helpful. Thanks.
How does one copy a mode? ie: "All motion on."
You can't "copy" per say... but you can re-create it by adding a new mode using the same cameras/formats/etc
Thank you.... And not good in English either so my Latin is crap too , nothing new 🙂
second mistake today...its been a hard day
I thought I was wrong once but I was mistaken...
This helped absolutely zero!
What are the differences in the modes?
Johnson4 wrote:This helped absolutely zero!
... there is NO DIFFERENCE, "MOTION ON" IS THE OLD DEFAULT FOR ARMED
