Arlo wireless
We just installed Arlo wireless and under device on settings it shows a hazard sign .... What does this mean? The cameras are working.
Also we are not getting push notifications when I have it "green" on to get push notifications for motion.
We get it stating like "geofencing is on" but not when motion is detected.
The red triangle just !sans a firmware update is available. It should update automatically.
Push notifications need to be enabled in any mode/rule you use as well as in the phone settings. Sometimes the setting for notifications for the Arlo app gets turned off (it's on by default). You could also try reinstalling the app.
