Arlo wireless unable to sync with base station
  • 1 Reply
  • 883 Views
LeslieVanSchaik
I am unable to sync my cameras to the base station.  All lights are green after I sync the first camera the camera light turns to amber.  The cameras are right next to the base station.  What should I try?
If the Camera LED is solid amber, your base needs to be claimed. Did you do that first? You may need to remove everything from Settings, My Devices and start fresh, claiming the base before anything else.
